Старый 17.04.2006, 08:53   #7
AndyD is offline
AndyD
КОРУС Консалтинг
2,560 / 2494 (89) +++++++++
Вот
static void ODBCConnection2Excel(Args _args)
    LoginProperty           LP          = new LoginProperty();
    OdbcConnection          myConnection;
    Statement               myStatement;
    ResultSet               myResult;
    DictTable               dictTable   = new DictTable(tableNum(InventTable));
    ComExcelDocument_Ru     Excel       = new ComExcelDocument_Ru();
    Com                     Doc;
    Com                     App;
    Com                     Worksheet;
    Com                     Range;
    int                     i = 1;
    Excel.newFile("", false);
    doc = Excel.getComDocument();
    App = doc.Application();
    Worksheet = App.ActiveSheet();
    LP.setDSN("Axapta");
/*    LP.setUsername("");       // Если необходимо - устанавливаем имя и пароль для подключения
    LP.setPassword("");*/
    try
        myConnection = new OdbcConnection(LP);
    catch
        info("Check username/password.");
        return;
    myStatement = myConnection.createStatement();
    myResult = myStatement.executeQuery(
        strfmt("SELECT %3, %4 FROM %1 WHERE DataAreaId = '%2'",
            dictTable.name(DBBackend::Sql), curext(),
            dictTable.fieldName(fieldnum(InventTable, ItemId), DBBackend::Sql),
            dictTable.fieldName(fieldnum(InventTable, ItemName), DBBackend::Sql)));
    Range = Worksheet.Range("A1");
    Range.NumberFormat("@");
    Range.Value2(dictTable.fieldObject(fieldnum(InventTable, ItemId)).label());
    Range = Worksheet.Range("B1");
    Range.Value2(dictTable.fieldObject(fieldnum(InventTable, ItemName)).label());
    while (myResult.next())
        Range = Worksheet.Range(ComExcelDocument_Ru::numToNameCell(1, i+1));
        Range.Value2(myResult.getString(1));
        Range = Worksheet.Range(ComExcelDocument_Ru::numToNameCell(2, i+1));
        Range.Value2(myResult.getString(2));
        if (i > 100) break;
        i++;
    Range = Worksheet.Range("A1", "B1");
    Range = Range.EntireColumn();
    Range.AutoFit();
    Excel.visible(true);
Axapta v.3.0 sp5 kr2
За это сообщение автора поблагодарили: Sada (1).
