Тема
casperkamal: InventDim id blank from "Axapta" to "AllBlank" in Dynamics Ax
26.02.2007, 18:40
1
846
79
Источник:
http://casperkamal.spaces.live.com/B...CD63!233.entry
Hey,
Just found out something interesting, the blank inventDimid(With all Inventory Dimesions blank)
"Axapta"
is no more the same, now it is refferred to
"AllBlank"
. I found it as i was digging to find the reason behind no records getting displayed in the
"Item"
form when I had records in the table.
The problem was the blank record in InventItemLocation, just a wrote a little job to get the things right.
Just copy and run it, if you find a bit lazy
to write ....
static void JobChangeAxaptatoBlankInventDim(Args _args)
InventItemLocation inventItemLocation;
while select forupdate inventDimId from inventItemLocation
ttsbegin;
if (inventItemLocation.inventDimId == 'Axapta')
inventItemLocation.inventDimId = 'AllBlank';
inventItemLocation.update();
ttscommit;
..................what else ???????
will see....
Источник:
Посмотреть профиль
Найти ещё сообщения от Blog bot
