Старый 23.12.2009, 22:23   #22
belugin is offline
belugin
Аватар для belugin
4,622 / 2925 (107) +++++++++
Записей в блоге: 5
Сообщение от DinDim Посмотреть сообщение
Скажите, а как осуществляется доступ клиентов в функцоналу AOS (remouting, wcf, com? или что-то другое), и изменился ли принцип доступа в 2009 AX?
http://msdn.microsoft.com/en-us/libr...02654.aspx#AIF
The programming model for AIF supports document services that encapsulate business logic and are the interface between Microsoft Dynamics AX and external systems. The document services can be customized by adding your own methods. Microsoft Dynamics AX now supports the ability to expose business logic implemented in X++ as Windows Communication Foundation (WCF) services. All services can be published through AIF asynchronous adapters or through WCF.
AIF provides functionality for consuming external Web services from within X++. This enables the integration with any external data provided as a Web service.
http://www.microsoft.com/downloads/d...displaylang=en
кстати http://www.microsoft.com/dynamics/en...connector.aspx
