xRecord.setTmpData
Run on: Server
Description
Sets the buffer it is performed on to use the same physical dataset as the buffer passed as parameter. This method is only applicable on a temporary table buffer using a buffer on a temporary table as parameter. The normal behaviour for temporary tables is that instances of the same table are isolated from each other. This method allows several buffer instances to operate on the same temporary data.
