Старый 04.03.2010, 10:01   #1
Kipetcoff is offline
Kipetcoff
Отправка писем из плагина
Создал плагин,который повесил на создание сущности. Пытаюсь отправить писма из него. Письма создаются,но не отправляются. Я раньше отправлял письма из кода моей страницыи все было прекрасно,теперь этот же код не работает.
Код:
InstantiateTemplateResponse instTemplateResponse = (InstantiateTemplateResponse)crmService.Execute(instTemplate);
						email emailCreate = (email)instTemplateResponse.BusinessEntityCollection.BusinessEntities[0];
						emailCreate.regardingobjectid = new Lookup();
						emailCreate.regardingobjectid.type = sContentType;
						emailCreate.regardingobjectid.Value = new Guid(sEntId);
						//specify the owner for the mail
						emailCreate.ownerid = new Owner();
						emailCreate.ownerid.type = EntityName.systemuser.ToString();
						emailCreate.ownerid.Value = userid;
						//created by
						emailCreate.createdby = new Lookup();
						emailCreate.createdby.type = EntityName.systemuser.ToString();
						emailCreate.createdby.Value = userid;
						activityparty apTo = new activityparty();
						apTo.partyid = new Lookup();
						apTo.partyid.type = sContentType;
						apTo.partyid.Value = new Guid(sEntId);
						emailCreate.to = new activityparty[] { apTo };
						// specify the from part of the email
						activityparty from = new activityparty();
						from.partyid = new Lookup();
						from.partyid.type = EntityName.systemuser.ToString();
						from.partyid.Value = userid;
						emailCreate.from = new activityparty[] { from };
						Guid emailId = crmService.Create(emailCreate);
						//attachment
						foreach (object oAttach in arrAttBodies)
							activitymimeattachment attachment = new activitymimeattachment();
							try
								annotation annot = (annotation)oAttach;
								if (annot != null)
									attachment.activityid = new Lookup();
									attachment.activityid.Value = emailId;
									attachment.activityid.type = EntityName.email.ToString();
									attachment.filename = annot.filename;
									attachment.body = annot.documentbody;
									attachment.mimetype = annot.mimetype;
									Guid attachmentId = crmService.Create(attachment);
							catch (System.Web.Services.Protocols.SoapException ex)
								//ErrorMessage("Create Attachments Error:" + ex.Detail.InnerText);
						//Send the Email
						try
							// Create an SendEmailRequest object
							SendEmailRequest req = new SendEmailRequest();
							req.EmailId = emailId;
							req.TrackingToken = "";
							req.IssueSend = true;
							// Finally Send the email message.
							SendEmailResponse res = (SendEmailResponse)crmService.Execute(req);
							iMailsCnt++;
							if (!bResult)
								bResult = true;
							//ErrorMessage("Send Mail Error:" + ex.Detail.InnerText);
Письма создаются,но они по запросу SendEmailResponse не отправляются...они висят пока его не откроешь и не отправишь вручную.
Единственную разницу которую мне удалось найти это то,что в поле Createdby теперь значение SYSTEM,хотя раньше туда писался пользователь под которым создавались письма.
Ошибка ни о чем "0x80040216 An unexpected error occurred. Platform"
Вопрос вобщем-то простой WTF?
