Старый 01.04.2011, 06:13   #1
Jim Wang: mSketch: Dynamics CRM 2011 Designer's Tool - Using Microsoft Expression Blend with Sketchflow
Источник: http://jianwang.blogspot.com/2011/03...designers.html
I have been asked to test the Magnetism mSketch application - a mockup tool for Microsoft Dynamics CRM using Microsoft Expression Blend with Sketchflow.
That is something I were looking for - to have a "CRM template" on Sketchflow, I'm so pleased to see it - well done Magnetism guys!
Imagine how quickly a CRM designer can draw a CRM screen quickly without doing the CRM form customisations, collect feedbacks from team/customer and get the design signed off quickly:
The designer opens the Microsoft Expression Blend 4 with Sketchflow, create a new Silverlight Sketchflow Application project , then drag-and-drop CRM elements on several screens, publish the design on to SharePoint site for the team/customer review, team/customer write comments/feedbacks directly onto the design, designer make changes accordingly, export the design into Microsoft Word document directly, email customer and get it signed off.
The Microsoft Expression Blend 4 with Sketchflow can do all above except the "CRM elements" - but where to get it? The mSketch helps here!
The current version of mSketch provides a Microsoft Expression project, you need to open the project first and then create your Silverlight Sketchflow Application project, and then copy/paste the CRM elements from 7 screens that comes with mSketch.
Here is the mSketch user guideline.
I hope in the next version, it can provide a installation package. Once installed, create a CRM mockup library in the Assets list of the Microsoft Expression Blend. The CRM mockup library provide the following elements for designers to allow quickly drag-and-drop, i.e.:
  • Global Icon Elements
  • Top Ribbon Bar Elements
  • Left Navigation Panel Elements
  • Entity Left Navigation Panel Elements
  • Entity Form Elements
  • Entity View Elements
  • Field Control Elements(textbox, lookup, picklist etc.)
mSketch is a handy tool for CRM designer and architectures.
Moving forward, I also hope the tool can provide more interactive actions with developers, i.e.: perform more CRM Form functions in Sketchflow.
