подождите, Mary.
id в командной строке, это не пользователь.
это имя файла, где хранятся настройки профиля.
Each user in a Navision Attain multiuser installation can choose the setup of windows and program properties that they want to use. Each user must have a unique ID, in order for the program to be able to save and use the setup selections of the individual users. You can create a user setup by starting the program with an ID. The information about the users’ setup will be stored under this ID. Here is an example in which the program starts with an ID called SUPER:
c:\Program Files\Navision Attain\fin.exe id=SUPER
In a list of Navision Attain program files, you can see that each time you have started with a new setup ID, a file has been created that has the ID as the first part of the file name and.zup as the file name extension (for example, super.zup). This is called a setup file.
