Попробуйте это
var authenticationHeader = GenerateAuthenticationHeader();
// Prepare the SOAP message.
var xml = "<?xml version='1.0' encoding='utf-8'?>"+
"<soap:Envelope xmlns:soap='http://schemas.xmlsoap.org/soap/envelope/'"+
" xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'"+
" xmlns:xsd='http://www.w3.org/2001/XMLSchema'>"+
authenticationHeader+
"<soap:Body>"+
"<Fetch xmlns='http://schemas.microsoft.com/crm/2007/WebServices'>"+
"<fetchXml><fetch mapping='logical'><entity name='equipment'><no-attrs/></entity></fetch></fetchXml>"+
"</Fetch>"+
"</soap:Body>"+
"</soap:Envelope>";
// Prepare the xmlHttpObject and send the request.
var xHReq = new ActiveXObject("Msxml2.XMLHTTP");
xHReq.Open("POST", "/mscrmservices/2007/CrmService.asmx", false);
xHReq.setRequestHeader("SOAPAction","http://schemas.microsoft.com/crm/2007/WebServices/Fetch");
xHReq.setRequestHeader("Content-Type", "text/xml; charset=utf-8");
xHReq.setRequestHeader("Content-Length", xml.length);
xHReq.send(xml);
// Capture the result.
var resultXml = xHReq.responseXML;
// Check for errors.
var errorCount = resultXml.selectNodes('//error').length;
if (errorCount != 0)
var msg = resultXml.selectSingleNode('//description').nodeTypedValue;
alert(msg);
// Process and display the results.
else
// Capture the result and UnEncode it.
var resultSet = new String();
resultSet = resultXml.text;
resultSet.replace('<','<');
resultSet.replace('>','>');
// Create an XML document that you can parse.
var oXmlDoc = new ActiveXObject("Microsoft.XMLDOM");
oXmlDoc.async = false;
// Load the XML document that has the UnEncoded results.
oXmlDoc.loadXML(resultSet);
// Display the results.
var results = oXmlDoc.getElementsByTagName('result');
var msg = "\Account Id\t\t\t\tAccount Name\r";
msg +="--------------------------------------------------------------------------------\r";
for (i=0;i < results.length;i++)
var idValue = results[i].selectSingleNode('./equipmentid').nodeTypedValue;
msg += idValue +"\t";
alert(msg);
Экстремал и буду экстремать!
Блога
