28.10.2006, 16:40
#1
Dynamics AX Geek: Using query()
Источник: http://AxGeek.spaces.live.com/Blog/c...DB13!148.entry
As the name implies QueryRun is the executor of a query linked to it. To construct a query you want QueryRun to execute, you need build classes:- Query
- QueryBuildDataSource
- QueryBuildRange
- QueryBuildFieldList
- QueryBuildLink
- QueryBuildDynaLink
Today’s example will use the first four to demonstrate a query that sums the credit limit field in CustTable grouped by Country and Currency. Additionally a count field indicates how many records are represented in the sum. Ranges are implemented for AccountNum and Country, but the user is allowed to add additional range criteria in the dialog. To demonstrate the status() property I have locked it, so the user can not change it.
QueryRun
QueryRun executes the query. If needed the familiar query dialog can be opened before the query is run. This is done using the prompt() method. SysQueryRun extends QueryRun and has a total of 7 prompt*() methods, with different default behavior. For example promptAllowAddRange() would allow the user to add new where-conditions.
Query
A query represents the select statement. This is where all the strings come together.
Using QueryBuildDataSources you add all the tables you want joined (just one in this example). This is also where you define how the resultset is to be sorted. The orderMode() method lets you define
QueryBuildRange
Ranges represent where conditions. Multiple ranges are connected with AND conditions. Unfortunately there is no easy way to change that.
QueryBuildFieldList
Represents the selected fields of the query. By default all fields are selected. In regular queries you probably wouldn’t use them that often, but when grouping this is the way to define which fields are calculated. SelectionField is an enum with the following values- Avg
- Count
- Database
- Max
- Min
- Sum
The result of Test_Query on my test system looks something like this:
CA CAD 1120,00 (3 records)
CA USD 500,00 (1 records)
DE EUR 0,00 (1 records)
DK CAD 5000,00 (1 records)
DK EUR 300,00 (6 records)
DK GBP 560,00 (2 records)
ES EUR 0,00 (1 records)
IE EUR 0,00 (1 records)
NL EUR 20,00 (2 records)
NO EUR 3000,00 (1 records)
static void Test_Query(Args _args)
CustTable custTable;
Query query = new Query();
QueryRun qr = new queryRun(query);
QueryBuildDataSource qbds = qr.query().addDataSource(tableNum(CustTable));
QueryBuildRange qbrAccN = qbds.addRange(fieldNum(CustTable,AccountNum));
QueryBuildRange qbrCountry = qbds.addRange(fieldNum(CustTable,Country));
QueryBuildFieldList qbfl = qbds.fields();
qbrAccN.value('4000..4050');
qbrAccN.status(RangeStatus::Locked);
qbrCountry.value('CA..NO');
qbfl.addField(fieldNum(CustTable,CreditMax),SelectionField::Sum);
qbfl.addField(fieldnum(CustTable,RecId),SelectionField::Count);
qbds.addSortField(fieldnum(CustTable,Country));
qbds.addSortField(fieldNum(CustTable,Currency));
qbds.orderMode(OrderMode::GroupBy);
if (qr.prompt())
while (qr.next())
custTable = qr.get(tableNum(CustTable));
print strfmt("%1 %2 %3 (%4 records)",custTable.Country,custTable.Currency,
num2str(custTable.CreditMax,10,2,0,0),custTable.RecId);
pause;
