Источник:
http://casperkamal.spaces.live.com/B...CD63!200.entry
I have developed a small wizard for the first time. As the name describes u can use this Wizard to generate XML for any table.
This wizard comes with the following features………- You can customize and choose the fields that you want in the xml
- You can specify a query which will govern the data to be sent in the xml.
- A schema file is generated that displays the data generated in the form of tables and not as normal XMLs.
- Fields that are at system level or visible property is set to “No” are not allowed in the xml.
- All mandatory fields are always included in the xml.
- The XML and style sheet gets saved in “C:\”
Complete detail of the wizard, screen shots and XPO are available in Axaptapedia under the following link
http://www.axaptapedia.com/Data_XML_Generation_wizard
..............................more features to come
Источник:
