Старый 15.04.2014, 07:17   #1
25,475 / 846 (79) +++++++
daxserver: Security Development Tool for Dynamics AX 2012: Issue with recording entry points
Источник: http://blogs.msdn.com/b/daxserver/ar...ry-points.aspx
When the task recorder was introduced in cumulative updates for AX 2012 and AX 2012 R2, it introduced a bug in the ability to record business process flows and identify the entry points used of the Security Development Tool for AX 2012. The user would press 'Start recording' in the tool, click through a few menu items and click on 'Stop Recording'. The expected behavior would be to see a list of all the menu items that were selected along the way. Instead, the user got a message "no entry points recorded."
A hotfix has been issued for this problem. Please download it from the following locations.
Ax 2012: https://support.microsoft.com/hotfix...?kbnum=2957068
Ax 2012 R2: https://support.microsoft.com/hotfix...?kbnum=2957067
Note that the fix is already built into AX 2012 R3 and no seperate patch will be required for that version.
Thank you for your patience on this issue and let us know if there are any more questions or concerns.
workflowax: Microsoft Dynamics AX 2012 Development Cookbook Blog bot DAX Blogs 0 27.06.2012 23:11
palleagermark: "Microsoft Dynamics AX 2012 Development Cookbook" review Blog bot DAX Blogs 0 05.06.2012 18:12
emeadaxsupport: Microsoft Dynamics AX 2012 Upgrade - Using the State Transfer Tool Blog bot DAX Blogs 0 28.01.2012 02:16
dynamics-ax: Interview with Microsoft's Lachlan Cash on his new role, AX 2012 and more Blog bot DAX Blogs 6 22.04.2011 14:55
Часовой пояс GMT +3, время: 16:07.
