Старый 22.04.2014, 18:11   #1
25,475 / 846 (79) +++++++
gustafwesterlund: Server side Sync Trouble shooting
Источник: http://gustafwesterlund.blogspot.com...-shooting.html
I have been working with a Proof-of-concept for the lates couple of Days and have been setting up the server side sync for a CRM on-premise system. First of all I would just like to share that it is a really nice new feature, I really like the fact that we now can have an option to not have to use the email router. With the new spring release, it will also be available for CRM Online, but only CRM-Online to Exchange Online (O365) not hybrid Environments (ex. CRM Online to Exchange on-premise or vice versa).
However, I did run into some issues as none of the emails that I sent to the email account connected to the queue showed up in the queue.
The Server Sync is handled by the MSCRMAsyncService and if you switch on logging in CRM (which can be done using adding the registry key "TraceEnabled" and setting it to 1 or using Power Shell) you will get the logging of the server sync in the async tracing loggs. It turned out that I had a missmatch in email addresses which CRM apparently didn't like and you can only have one email address for a queue, but it was easily fixed once I knew the problem. I just wonder how I would troubleshoot this if I got this in CRM Online... hopefully MSFT will be adding additional logging to the server sync functionality.
Gustaf Westerlund
MVP, CEO and owner at CRM-konsulterna AB
www.crmkonsulterna.se
CRM DE LA CREME! CRM 4.0 Disaster Recovery Blog bot Dynamics CRM: Blogs 2 26.02.2016 08:23
sumitsaxfactor: Browsing Folders for Files on 64-bit Server Side Implementation (Batch Run) Blog bot DAX Blogs 0 26.08.2011 01:13
gustafwesterlund: Email router on Windows Server 2008 R2 Blog bot Dynamics CRM: Blogs 0 05.04.2011 06:13
chrisfie: Project Server 2007 TechNet Webcasts recordings and decks Blog bot DAX Blogs 0 21.07.2009 10:05
Microsoft Dynamics CRM Team Blog: Building a Self-Contained Virtual CRM Development Server Blog bot Dynamics CRM: Blogs 0 05.05.2009 10:05
Часовой пояс GMT +3, время: 01:49.
