Старый 12.09.2014, 03:25   #1
25,475 / 846 (79) +++++++
lcs: Known issue: Cloud-hosted environment errors for some users
Источник: http://blogs.msdn.com/b/lcs/archive/...ome-users.aspx
We are aware of two different issues impacting some user's ability to use Cloud Hosted environment management features. We are working to resolve these issues. In the meantime you can use the workarounds below.
Issue: “You can’t update the deployment at this time. Please wait for a moment, and then try again. If the issue persists, contact support”.
Scenario: You created a Lifecycle Services project. In the LCS Cloud-hosted environments portal you start deploying an environment, and receive the error above after clicking +.
Cause: The javascript cache in your browser is not refreshing.
Workaround: Clear your browser cache or press Ctrl+F5.
Issue: “An error has occurred. This error has been logged in our datacenter”
Scenario: You created a Lifecycle Services project. In the LCS Cloud-hosted environments portal you start deploying an environment, and receive the error above after clicking +, selecting a topology, and then clicking Next.
Cause: The call to Azure to enumerate virtual networks in the Azure subscription is raising an unhandled exception because there are no virtual networks defined.
Workaround: Create a new virtual network in your Azure subscription.
  1. Log in to https://manage.windowsazure.com.
  2. Click + New at the bottom right.
  3. In the New pane, click Network Services > Virtual Network > Custom Create.
  4. Enter a name for the virtual network.
  5. Leave the defaults for all other options.
  6. Click Create Virtual Network.
  7. Return to LCS and retry your deployment.
lcs: Known issue: Customization analysis issue for Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 0 12.09.2014 03:25
dynamicsaxbi: Known Issue: Relative path errors when using version control Blog bot DAX Blogs 0 21.03.2014 01:11
lcs: Improvements to Issue Search Blog bot DAX Blogs 0 28.02.2014 04:47
Microsoft Dynamics CRM Team Blog: Customizing OU User Access in a Hosted Environment Blog bot Dynamics CRM: Blogs 0 18.07.2009 09:10
Часовой пояс GMT +3, время: 10:46.
