Старый 14.04.2015, 15:11   #1
25,475 / 846 (79) +++++++
axStart: delete an AX 2012 R2 or R3 partition
Источник: http://www.axstart.com/delete-an-ax-...-r3-partition/
We are able to delete a company in AX, but deleting a partition is not possible.
So why not? It should be easy to create a partition and put data in it with tools like DMF, to enable us to create ad hoc demo / training partitions. Having played for a while with some SQL code, the following code was obtained.
First browse the partitions table to find the RecId of the partition one wants to delete.
The script below contains SQL code to delete PS, EXT and Cube partitions.
Be careful don’t delete the initial partition or a partition with production data. Also note that it will not ask for a confirmation when you run this script. I would strongly recommend you to create a backup of the database before running this.
This script is ‘as-is’. There are no guarantee on this code. I you use it, test it carefully. The results are your responsibility.
It is also possible to delete a company in AX 2012, however you have to delete first all transactions with class sysDatabaseTransDelete (see also http://daxture.blogspot.nl/2014/09/d...n-ax-2012.html)
As a side not, cleaning up the partition on the Contoso demo data will not reduce the size of your database.
emeadaxsupport: How to use the Manual Billing Rule for Projects in Microsoft Dynamics AX 2012 R2 and AX2012 R3 Blog bot DAX Blogs 0 03.03.2015 19:11
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 2012 R3 RTM Warehouse Management: How to prevent the creation of two inventDim records considered identical in Dynamics AX 2012 R3 RTM Blog bot DAX Blogs 0 22.12.2014 19:12
emeadaxsupport: AX Performance Troubleshooting Checklist Part 2 Blog bot DAX Blogs 0 09.09.2014 16:11
DAX: A Shift to Effective Demand Forecasting With Microsoft Dynamics AX 2012 R3 Blog bot DAX Blogs 0 16.11.2013 02:13
dynamicsaxbi: Better together: Microsoft Dynamics AX 2012 R2 and SQL Server Power View Blog bot DAX Blogs 0 12.12.2012 13:11
Часовой пояс GMT +3, время: 02:31.
