Старый 30.04.2016, 03:35   #1
25,475 / 846 (79) +++++++
lcs: Deprecated: Application hotfix in asset library
Источник: https://blogs.msdn.microsoft.com/lcs...asset-library/
We will be deprecating Application hotfix in asset library with the next update of LCS to pave way for an improved servicing experience. Please make sure you download and backup an data you may have uploaded to LCS. If you have question, feel free to reach out to Dynamics support through our support channels.
emeadaxsupport: Warning when installing AX 2012 R3 Application hotfix: The model store you selected requires a newer version of the installer than the one you're using. Blog bot DAX Blogs 0 03.09.2015 15:11
emeadaxsupport: AX Performance Troubleshooting Checklist Part 1B [Application and AOS Configuration] Blog bot DAX Blogs 0 05.09.2014 21:11
daxmusings: TFS Build Library "Hotfix" Update - Beta of AX2009 TFS Library Blog bot DAX Blogs 0 13.08.2014 08:11
emeadaxsupport: After installing application Hotfix released on KB #2786631, it is not possible to cancel Invoice in Invoice approval journal on AX 2009 SP1 RU6 or higher Blog bot DAX Blogs 0 22.08.2013 14:11
Часовой пояс GMT +3, время: 11:40.
