Старый 21.02.2017, 09:11   #1
25,475 / 846 (79) +++++++
organicax: Working around the modifiedBy error when publishing an entity to the entity store
Источник: https://organicax.com/2017/02/20/wor...-entity-store/
In a previous post we had a look at setting up the entity store. As you saw in that video there are a lot of the standard entities that you won’t be able to published to the entity store as you will get a ModifiedBy error.
This is annoying because it means out of the standard 476 entities in CU11 you will only be able to published about 106 without error. Now a lot of the standard entities are designed to move parameters or master data they aren’t really BI related entities that aggregate data so this may not be a big issue as you will likely have to create your own entities. If you do want to use these standard ones then you will have to make some modifications to get around the ModifiedBy error.
The actual error will be something to the effect of “Please make sure that all tables in the ‘entityname’ query has the ModifiedBy property enabled.”
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Business intelligence, Data migration
organicax: Report logo on legal entity setup Blog bot DAX Blogs 0 02.11.2016 01:11
organicax: Entity Store AX2012 R3 CU11 Blog bot DAX Blogs 0 29.10.2016 03:41
dynamicsaxbi: Introducing Entity Store for Dynamics AX 2012 R3 Blog bot DAX Blogs 21 26.09.2016 17:30
jaestevan: Descubre la nueva Dynamics AX 2012 R3 Entity Store Blog bot DAX Blogs 0 23.06.2016 18:11
fed: Net requirements update in MRP Module and Working Set of MRP Blog bot DAX Blogs 14 08.05.2012 13:09
Часовой пояс GMT +3, время: 19:58.
