Старый 02.04.2009, 19:05   #1
25,477 / 846 (79) +++++++
AX 2009 Technical Journal: Debugging Batch Jobs
Источник: http://ax2009tech.blogspot.com/2009/...atch-jobs.html
We have a hard time getting the AX 2009 debugger to work when breakpoints are set in code executing in Batch Jobs. Microsoft has described this in several documents without any special requirements, but we are unable to get the debugger to work as expected. All settings are correct in the server configuration and in the client when the breakpoint is defined. We have also tried to use the keywork breakpoint in the code without any difference. It seems like the debugger has a hard time attaching to the process. We have tried this in several environments and solutions, and in different combinations, and basically we are stucked.
The fundamental changes in the Batch Framework requires more debugging than ever due to the increased complexity inherited from the changes around impersonation (RunAs) and the prmiary tool in this situation is in fact the debugger.
We have also checked with several other sources and they have done the same experience.
All experience around this issue is highly welcome.
AX 2009 Technical Journal: LIVE Blog bot DAX Blogs 2 31.03.2009 12:05
AX 2009 Technical Journal: The haunt for knowledge Blog bot DAX Blogs 0 31.03.2009 12:05
Microsoft Dynamics AX 2009 White Paper: Journal Batch Posting Vadik DAX: База знаний и проекты 0 02.10.2008 15:52
Часовой пояс GMT +3, время: 11:33.
