Старый 12.09.2007, 06:11   #1
Dynamics AX: Mass Deployment of the Microsoft Dynamics AX Client
Источник: http://dynamics-ax.blogspot.com/2007...-dynamics.html
"This paper describes how to mass deploy the Microsoft Dynamics AX Client using Microsoft Dynamics AX Setup, a configuration file, and a mass deployment tool such as Group Policy or Microsoft Systems Management Server."
Mass Deploy for Dynamics AX Client White Paper link [requires PartnerSource Access]
The above white paper talks about deploying the Microsoft Dynamics AX Client via Group Policy and Systems Management Server for enterprises that would have a need to deploy and update the client from a central location. This comes in handy for small IT shops, or larger than 100 client machine networks that will use the client. I wrote about this some time back, and some comments where left about the details of doing this. Well here is the exact white paper that will walk someone in an enterprise that needs the ability to do this with! Hope it helps!
Check back soon!
Find a job at: www.DynamicsAXJobs.comFind a job at: DynamicsAXJobs.com, also post a job for only $99.00!
