Старый 14.06.2009, 12:05   #1
DeniZone: ODBC with FoxPro
Источник: http://denizone.blogspot.com/2009/06...th-foxpro.html
I recently had the pleasure of adventuring into the ODBC connection territory. I discovered that many others previously had done the same ( obviously ) but there was a surprising lack of how-to and other documentation. After some extensive searching I found Brandon's blog in which he meticulously documented an implementation of ODBC. Many excellent observations are included in his description, including AOS considerations, i.e. code-execution placing vs. maintenance of Windows ODBC connection ( he runs the code on the AOS server so that the system ODBC connection driver only needs to setup there and not on the client which would reduce maintainability as changes to the connection potentially would have to be distributed to all clients ).
If you are implementing an ODBC connection for the first time on AX 2009, I highly recommend reading Brandon's step-by-step description.
So implementig an ODBC connection should be a run of the mill type of assignment, had it not been for one small detail... FoxPro. One of Brandon's main consideratations was exactly that the ODBC connection should be created on the AOS, but the systems requirements for the AOS in the case in question on which the ODBC connection would be created stated that the OS ( Windows Server 2008 ) should be 64-bit, and FoxPro only runs 32-bit and since the AOS instance in AX2009 runs in 64-bit mode - it cannot access the 32-bit FoxPro drivers ( and as far as I could tell there never will be a 64-bit implementation of the ODBC drivers for FoxPro ).
So maintainability aside - I had to distribute the ODBC connection to all clients force the class which handles the code to run on the client. This can be done since the AX2009 client still runs 32-bit ( and in 32-bit mode on 64-bit OS ).
Task completed - but the journey probably would have been longer and more tedious had it not been for Brandon's blog.
Hope my expericences with FoxPro ODBC connection in connection with AX2009 helps someone, just as Brandon's blog helped me.
Happy hacking
