Старый 01.03.2004, 08:10   #1
renat is offline
renat
Аватар для renat
142 / 12 (1) ++
может быть...
вот чего написано в BEST PRACTICE
If you log on to the CUS layer, and import some application objects, all the imported application objects will be placed in the CUS layer.
- existing application objects in the USR layer will be left unchanged, but be "underridden" with the imported ones in the CUS layer. (So the USR layer probably has to be updated!)
(а тут не понятно значение слова "underridden")
- existing application objects in the CUS layer will be lost and replaced with the imported ones.
(существующие объекты в CUS слое будт замещены импортируемыми !!!!)
- existing application objects in the GLS layer (or any layer lower than CUS) will be overridden with the imported ones in the CUS layer.
- Non-existing (i.e. new) application objects will be placed in the CUS layer.
