Старый 21.05.2008, 01:25   #1
So my day job has been keeping me very busy (which is never a bad thing)...
I have managed to delve a little deeper into message queues, and although documentation exists, it can be a little ambiguous. Here is what I have found...
NAV and Message Queues
WritePrivateQueue()
CREATE(CC2);
CREATE(MQBus);
CC2.AddBusAdapter(MQBus,1);
MQBus.OpenWriteQueue('.private$TestWriteQueue',0,0);
MQBus.SenderAuthenticationLevel:= 2;
OutMsg := CC2.CreateoutMessage('Message queue://.private$TestWriteQueue');
OutS := OutMsg.GetStream();
OutS.WRITE('Hello world! - WritePrivateQueue');
OutMsg.Send(0);
Variables
Name
DataType
Subtype
MQBus
Automation
'Navision MS-Message Queue Bus Adapter'.MSMQBusAdapter
CC2
Automation
'Navision Communication Component version 2'.CommunicationComponent
OutMsg
Automation
'Navision Communication Component version 2'.OutMessage
OutS
OutStream
The code above will write to a new private message queue on the local machine called: TestWriteQueue
The message is called: Navision MSMQ-BA
At the same time a message called: Navision MSMQ-BA is created in the public queue called: nsadminreceivequeue - not too sure what this one does or is as it is blank – it seems to be the admin queue used to deliver the message to the correct queue as it states – “The message reached the queue.”
Receiving & Displaying MessagesOnRun()
CREATE(MQBus);
CREATE(CC2);
MQBus.OpenReceiveQueue('.private$TestWriteQueue',0,0);
CC2::MessageReceived(VAR InMessage : Automation "''.IDISPATCH")
InMsg := InMessage;
InS := InMsg.GetStream();
InS.READ(Txt);
MESSAGE(Txt);
InMsg.CommitMessage();
Name
DataType
Subtype
Length
MQBus
Automation
CC2
Automation
WITHEVENTS
InMsg
Automation
'Navision Communication Component version 2'.InMessage
InS
InStream
Txt
Text
100
This code will receive the message sent by WritePrivateQueue and then display the text in message in NAV. This codeunit must be running single instance so that it can respond to the event.
WritePrivateQueueandReply()
CREATE(CC2);
CREATE(MQBus);
MQBus.OpenReplyQueue('.private$TestReadQueue',0,0);
MQBus.SenderAuthenticationLevel:= 3;
OutS:= OutMsg.GetStream();
OutS.WRITE('Hello world! - WritePrivateQueueandReply');
InMsg:= OutMsg.SendWaitForReply(3000);
IF ISCLEAR(InMsg) THEN
MESSAGE('InMsg not received')
ELSE
BEGIN
InS:= InMsg.GetStream();
InS.READ(Txt);
MESSAGE(Txt);
END;
Variables
Name
DataType
Subtype
Length
MQBus
Automation
CC2
Automation
OutMsg
Automation
OutS
OutStream
InMsg
Automation
InS
InStream
Txt
Text
100
This time we wait for a response back after sending the machine.
The system is not receiving the reply!!!
<h4 style="MARGIN:auto 0cm;">Public/Private Queues</h4>
A public queue is a queue that is registered in the directory service that any Message Queuing application can locate. Public queues are persistent. You can make a backup of their registration information, which makes them suitable for long-term use.
A private queue is a queue that is registered on the local computer (not in the directory service) that other applications typically cannot locate. Private queues have the advantage of having no directory service overhead. This means that they are faster to create, there is no latency and no replication. Further, they can be created and deleted when the directory service is not working.
Подробнее... http://dynamicsuser.net/blogs/nav2dotnet/a...age-queues.aspx
Часовой пояс GMT +3, время: 14:53.
