Старый 22.01.2010, 21:05   #1
emeadaxsupport: How to install AX 4.0 Reporting Role with SSRS 2008
Источник: http://blogs.msdn.com/emeadaxsupport...ssrs-2008.aspx
Some time ago we got question how to install AX 4.0 Reporting Role with SQL Server 2008. As every time when you are trying to install Reporting Services extension from AX 4.0 installation wizard, partner has got error:
"SQL Server Reporting Services must be installed before a Microsoft Dynamics AX reporting server can be set up."
The problem is probably somewhere in axsetup. Although we managed to create workaround. The workaround is to create manually the actions axsetup is doing, so we do not need to launch axsetup anymore.
To workaround the problem you need to:
1. Go to report manager
2. Create new folder call Dynamics
3. Create new data source called “Dynamics Database” with following settings:
    a. Enable this data source: true
    b. Connection type: Microsoft SQL Server
    c. Connection string:
initial catalog=DynamicsAXDatabaseName;Application Name=Dynamics;data source=DatabaseServerName;
    d. Connect using: select “Credentials stored securely in report server” - put the domain account name which has publishing rights for this instance for SRSS
    e. Select “Use as Windows credentials when connecting to data source”
4. Go to Dynamics AX Client
5. Go to Tools > reporting tools > reporting server
6. Specify the urls for Report Server and Report Manager.
7. Check on Advanced tab if folder name and data source name are the same as one created
8. Click validate button.
9. Try to update report model
To learn more about configuring report builder please visit: http://msdn.microsoft.com/en-us/library/ms365173.aspx
To learn more about SRSS security please visit: http://msdn.microsoft.com/en-us/library/ms156034.aspx
One more issue you can run into when you use reporting extensions for DAX 40: https://mbs.microsoft.com/knowledgeb...&wa=wsignin1.0
Старый 23.01.2010, 01:21   #2
EVGL is offline
EVGL
Banned
4,445 / 3001 (0) ++++++++++
Наш "специалист по новинкам" и общим ИТ смотрел, смотрел на богатства AX 2009 и 4.0, и вышел как раз сегодня с разумным предложением: продавать и устанавливать Enterprise Portal, Sharepoint и роли - нецелесообразно. Исключительно муторной он признал интеграцию ролевого центра с SSRS, все эти цветные столбики. Система усложняется, в ней появляется масса уязвимых и узких мест, а выгода для клиентов, как правило, стремится к нулю. Ну в самом деле: какое предприятие будет принимать решение о покупке системы по наличию или отсутствию "ролевого интерфейса"?
Старый 23.01.2010, 08:02   #3
Наш "специалист по новинкам" и общим ИТ смотрел, смотрел на богатства AX 2009 и 4.0, и вышел как раз сегодня с разумным предложением: продавать и устанавливать Enterprise Portal, Sharepoint и роли - нецелесообразно. Исключительно муторной...
Пусть посмотрит NAV 2009.
Там то же самое, но "муторности" на порядок меньше.
роли сами по себе (графики, стопочки, задания и уведомления другим пользователям) - штука классная (конечно же, дополнительно к основному функционалу).
Другое дело, что конкретная реализация этих ролей в Аксапте... Люди оторвались и наваяли...
emeadaxsupport: AX 2009 Setup fails to install IIS Components on Windows Server 2008 R2 Blog bot DAX Blogs 0 12.01.2010 04:44
emeadaxsupport: Debugging Microsoft Dynamics AX 2009 SSRS reports with Microsoft Visual Studio 2008 Blog bot DAX Blogs 0 26.07.2009 15:07
Solutions Monkey: Convergence 2008 - Microsoft Dynamics AX Enterprise Portal and Role Centers Blog bot DAX Blogs 0 09.03.2008 17:07
Часовой пояс GMT +3, время: 04:45.
