sinedax: Trace Parser doesn't work - Dynamics 365 for Finance & Operations
Источник: http://sinedax.blogspot.com/2018/12/...amics-365.html
============== Hi All and Happy Christmas!! Below, I'll share an issue that wasted my time during an Performance investigation. I have to say also thanks to Microsoft Technical support for helping me. Some ETL files opened with Trace Parser on a onebox VM, didn't show up any methods and any queries. Something like that: Cause: The ETW Providers “Microsoft-AX-XPPExecutionTraces” and “Microsoft-Dynamics-AX-ExecutionTraces” aren't installed in the VM! Microsoft-Dynamics-AX-XppExecutionTraces : Used to capture X++ methods events. Microsoft-Dynamics-AX-ExecutionTraces : Used to capture SQL events. Resolution : In that case you can install the missing providers with the following steps: Find the location of the manifest files. If you are using a onebox VM they are in C:\AOSService\webroot\Monitoring Open a Powershell as Administrator and run the following commands to install the 2 missing event providers: $resourcefiledir = "C:\AOSService\webroot" $inputmanfile = "C:\AOSService\webroot\Monitoring\DynamicsAXExecutionTraces.man" $outputmanfile = "C:\AOSService\webroot\Monitoring\DynamicsAXExecutionTraces_copy.man" $temp = Get-Content $inputmanfile $temp = $temp -replace "%APPROOT%",$resourcefiledir $temp | out-file $outputmanfile wevtutil im $outputmanfile $inputmanfile = "C:\AOSService\webroot\Monitoring\DynamicsAXXppExecutionTraces.man" $outputmanfile = "C:\AOSService\webroot\Monitoring\DynamicsAXXppExecutionTraces_copy.man" $temp = Get-Content $inputmanfile $temp = $temp -replace "%APPROOT%",$resourcefiledir $temp | out-file $outputmanfile wevtutil im $outputmanfile Close and open Trace Parser again and verify the providers are visible in the list. Another way is to: Copy c:\Monitoring folder from a 7.2 working VM Run MonitoringInstall.cmd from Command Prompt running as Administrator in this folder I guess with the new VM version this issue is gone! Enjoy! Источник: http://sinedax.blogspot.com/2018/12/...amics-365.html
Опции просмотра | |
